Re: Super H Clutch Won't Disengage Engine
Posted by Ken in Iowa on June 26, 2001 at 12:32:14 from (32.100.141.212):
In Reply to: Super H Clutch Won't Disengage Engine posted by Terry Filipiak on June 25, 2001 at 19:01:43:
Through the years I have had several clutches stick. If you have an inspection plate remove it and spray WD-40 or a similar penetrating oil on the back side of the flywheel and clutch disk. If no other access is available try removing the starter. After soaking it for a while start the engine if you can with the transmission in 3rd or 4th gear then hold the clutch pedal down and move the throttle control from fast to slow several times quickly and they will usually pop loose. Good Luck, Ken
Post A Followup
: Re: Re: Super H Clutch Won't Disengage Engine
