Re: Re: Re: farmall 140 bogs down
Posted by john michels on June 28, 2001 at 07:38:02 from (205.204.186.162):
In Reply to: Re: Re: farmall 140 bogs down posted by jack on June 28, 2001 at 04:41:11:
Thanks for the suggestions, I'll check these things out, but one thing that makes me think it is not fuel starvation problem is that when the tractor is not in gear I can give it as much gas as I want without any problems. Only when I want the tractor to do work do I run into problems. Does this indicate more of a compression problem?
Post A Followup
: Re: Re: Re: Re: farmall 140 bogs down
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
