Re: Need all the help I can get on replacing rear housing on H.
Posted by Jeff on June 28, 2001 at 09:44:30 from (63.150.94.35):
In Reply to: Need all the help I can get on replacing rear housing on H. posted by Nick on June 28, 2001 at 09:27:11:
A year ago I got an H with the transmission removed. It was fairly easy to put back in. The rear of the sliding gear shaft has 3 or 4 bolts you remove, and the front is a roller bearing that just slides out of the middle of a gear that connects to the constant mesh gear. This gear, and the belt pulley gear, are held in place by 5 or 6 9/16" bolts located in the chassis where the hydraulic pump unit goes. You can remove it without removing the pump, but IT'S A PAIN! You're better off removing the pump (which is very heavy). The rear of the counter shaft sets in a ball bearing and stays there with a snap ring. The front of the counter shaft screws into a coupling for the hydraulic pump shaft; there is also an oil seal. One trick is when you mate the front of the sliding gear shaft bearing with the constant mesh gear: make sure you put them together carefully, because the roller bearing retainers will unseat the rollers if they have much force put on them (I did this last fall). The best reference I had was the parts catalog and the engine service manual; I studied them a lot before I did anything. I also have pictures of the gears in place as well as other transmission housing pictures (1940 H).
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
