Re: cub dies
Posted by Dave G on June 28, 2001 at 20:04:37 from (158.252.165.104):
In Reply to: cub dies posted by gary2n on June 27, 2001 at 17:18:35:
If you are sure it is an electrical problem make sure the 12V wire to coil is not intermittent. Check all the connections, wire and switch. Also check the points and condenser. Points can get bad and act really strange. Don't file them, get new ones if bad. Check the distributer cap and rotor to make sure that connection looks good. Is the battery or are you jump starting it - make sure you have enough battery voltage. If battery is really bad it can stall at idle speeds.
Post A Followup
: Re: Re: cub dies
