Re: 1951 international 300 farm tractor
Posted by Denny Frisk on June 29, 2001 at 06:55:10 from (12.4.181.2):
In Reply to: 1951 international 300 farm tractor posted by Elmer on June 29, 2001 at 05:15:20:
If factory Power steering IS on the tractor You should be able to see the unit above the back of the engine way up inside the hood. Big cast iron unit about 15 inches long with the steering shaft running into & out of the unit. It's powered by the live hydraulic pump mounted between the timing gears and distributor on the right side of the engine as You sit on the seat. Power steering wasn't common on the 300's. Most 350's I've seen have it. If it has add-on P/S the separate pump "MAY" be installed on the upper left side of engine right behind the radiator. The steering unit would be in the same place, only smaller, about 9-10 inches long and 3-4 inches in dia.. It too may be plumbed into the live Hyd. system for power. Red's correct on the model years. '54 & '55 for sure. I'm not sure exactly when the 350 was introduced, in '55 or '56.
Post A Followup
: Re: Re: 1951 international 300 farm tractor
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
