Re: need advise on my new tractor
Posted by big fred on June 29, 2001 at 21:15:32 from (208.51.245.140):
In Reply to: need advise on my new tractor posted by FC Andy on June 29, 2001 at 19:07:16:
I think the C has the same type of coolant drain pipe that the A and B have, a short section of pipe extending down from the lower hose fitting on the block. It should have a pipe cap on it that you remove to drain the system. When you refill, make sure you have the coolant pre-mixed before adding it as you don't have a pump to mix it after it is in. The antifreeze and water have different densities and if not premixed the thermosiphon will not work and your engine will overheat. Enjoy your C!
Post A Followup
: Re: Re: need advise on my new tractor
