Update On Old Rusty H
Posted by The Red on June 30, 2001 at 07:58:18 from (12.75.221.53):
Or should I say OLD STUBBORN! I did get #3 pushed out last Sunday or Monday. #2 pushed up an inch this morning. Since PB Blaster is dripping between #2 outer sleeve and the cylinder wall, I will be concentrating on trying to get it out today. I am using a 12 inch by 3/4 inch i.d. water pipe. It is currently next to the connecting rod pushing directly on the bottom of the piston at the wrist pin.
I did get #4 pushed up far enough to get a 9/16" socket and a 3/8" U joint connected on the top rod cap bolt. When I tried to unbolt it, I broke the U joint and an extension. So that bolt is still on at this point in time.
Post A Followup
: Re: Update On Old Rusty H
