Re: Help on Hydraulics for Farmall M?
Posted by The Red on June 30, 2001 at 14:05:53 from (12.75.196.113):
In Reply to: Help on Hydraulics for Farmall M? posted by Lugaidh on June 30, 2001 at 13:49:06:
All three pipes are pressurized outlets. Is one of the hoses on the cylinder suppose to be a return line? If so, you will have to plumb it into the fill pipe for a return.
Post A Followup
: Re: Re: Help on Hydraulics for Farmall M?
