Re: Farmall Super A Hydraulics Touch-Control System
Posted by Haas on July 01, 2001 at 05:25:49 from (129.37.117.232):
In Reply to: Farmall Super A Hydraulics Touch-Control System posted by Sharon on June 30, 2001 at 18:54:35:
Like Vern says, disconnect the rods from the levers and see what is stuck. If it is the levers, loosen the tension nut that is on the outside of the lever shaft, use a lot of penetrating oil and work it loose. Then adjust the tension to give the proper amount of resistance. If the problem is in the touch control unit you have a bigger problem.
Post A Followup
: Re: Re: Farmall Super A Hydraulics Touch-Control System
