Re: Stronger Hydraulic Pump for the M?
Posted by Les Repair on July 01, 2001 at 15:42:06 from (206.28.174.53):
In Reply to: Stronger Hydraulic Pump for the M? posted by Lugaidh on July 01, 2001 at 14:36:04:
If you are going to run the pump from the timing gears on a M and you want 2500 pounds pressure, it better not have more than 2 gallon per minute flow. Anything with that much pressure pulls so hard that it will take the timing gears right out. BEEN THERE DONE THAT. The timing gears become the relief valve. Sorry
Post A Followup
: Re: Re: Stronger Hydraulic Pump for the M?
