Re: Story of an H
Posted by ff316 on July 01, 2001 at 19:32:33 from (63.31.171.96):
In Reply to: Story of an H posted by BTD on June 30, 2001 at 17:18:51:
You stated you replaced the sediment bowl and drained the gas tank - is it possible you could have got a piece of crud in the fuel line? Have you tried to disconnect the line at both ends and blow air through it? Just a thought, let us know when you figure it out - fireman
Post A Followup
: Re: Re: Story of an H
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
