Re: Re: Re: Re: Story of an H
Posted by Denny Frisk on July 02, 2001 at 11:44:05 from (12.4.181.2):
In Reply to: Re: Re: Re: Story of an H posted by Ben on June 30, 2001 at 19:09:08:
And that the timing is close if not correct. Sounds like a stuck needle or float valve in the carb.
Post A Followup
: Re: Re: Re: Re: Re: Story of an H
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
