Re: Re: Re: Changing Rear Tires
Posted by S-E Michigan Part Timer on July 02, 2001 at 16:33:28 from (198.208.6.34):
In Reply to: Re: Re: Changing Rear Tires posted by George Willer on July 02, 2001 at 06:36:59:
Of course, the easiest way as suggested is to have it done. If you want to tackle it, I haven't found a tire yet that will stand a chance against a slide-hammer. With the right tire tools and a slide hammer, I can have a 12x38 off the rim in about 10 minutes or less. Depends if you have it flat on the ground or on the tractor. All the tools you need are available at most farm supply stores- such as TSC in these parts.
Post A Followup
: Re: Re: Re: Re: Changing Rear Tires
