Re: Camber or caster
Posted by George Willer on July 04, 2001 at 07:05:28 from (64.254.131.14):
In Reply to: Camber or caster posted by Dick A on July 03, 2001 at 06:05:38:
It is natural to assume the wide fronts and narrow fronts have camber for the same reasons. You will really impress your wife if you explain the difference.
The narrow front has camber simply to get the bottoms closer together for easier steering, while still allowing clearance at the top for the pedestal.
The wide front is a different case. The camber and king pin inclination working together cause the tractor to rise when in a turn. The weight of the tractor causes the wheels to tend to return to straight ahead. (because it is lower then) We are so used to this effect that we don't even notice it, but without camber, the steering would wander badly. You will notice it if you note how much easier it is to return to straight ahead than it is to turn. Camber and inclination working together also put the point of rolling resistance in line with the king pin.
George Willer
Post A Followup
: Re: Re: Camber or caster
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
