Re: ballast resistor for 12v conversion
Posted by RickB. on July 04, 2001 at 10:16:00 from (205.231.26.227):
In Reply to: ballast resistor for 12v conversion posted by dan on July 04, 2001 at 09:25:23:
If you are reading voltage with the tractor shut off, points open and switch on, you will measure 12v on both sides of the resistor. Take voltage reading with tractor running, or points closed; switch on. There is no voltage drop across a resistor without a load applied to it.
Post A Followup
: Re: Re: ballast resistor for 12v conversion
