Farmall Cub engine miss
Posted by John on July 04, 2001 at 14:49:26 from (165.247.129.143):
My newly rebuilt Cub engine has an occassional miss or stumble that is worse at low rpms but also present at higher speeds. The carb has been rebuilt, float level set to shop manual spec and is clean as a whistle. Tank has been cleaned and sealed. Valves adjusted to 0.013" cold. Timing set statically. Changes in timing seem to make the miss worse or slightly better but do not eliminate it. Plugs are brand new Autolite equivalents of D21 Champions. Points replaced and adjusted, rotor replaced, new cap and plug wires. Any suggestions?
Post A Followup
: Re: Farmall Cub engine miss
