To John N on thermosyphon system
Posted by RAW in IA on July 04, 2001 at 15:44:31 from (206.28.170.218):
John, I checked the temp on my Cub today, and running down the road not under a big load it ran between 210 & 215 deg. at the top of the radiator. With a 50/50 antifreeze mis it willnot boil at that temp., and being as the thermosyphen system runs on temp differential, I think that is normal. Actually, the hotter an engine runs without boiling the coolant, the more efficient and betterit will run. Just keep it full and it should be okay.
Post A Followup
: Re: To John N on thermosyphon system
