Re: Fender Extensions
Posted by Andy Martin on July 04, 2001 at 16:18:41 from (38.31.74.83):
In Reply to: Fender Extensions posted by JDM on July 04, 2001 at 08:06:21:
Of 3 M's I have with fenders, one has no extensions, one has 1-1/4" long pipe extensions around the mounting bolts to raise the fenders, and one has 1-1/2" long pipe to raise the fender with 3/8 by 4" plate to offset the fender. Fender is offset the same as the bolt dimension, about 2-3/4", so the fender is 5-1/2" out from its mounting holes. Bracket has 8 holes all evenly spaced, and inner holes on fender are 2-3/4" outside of outer holes on axle. The 3/8 plate makes for a sturdy bracket. 1/4 might be a little light, and 5/16 might be OK.
Post A Followup
: Re: Re: Fender Extensions
