Re: relief valve for Farmall M Hydraulics?
Posted by Andy Martin on July 04, 2001 at 17:11:11 from (38.31.74.83):
In Reply to: relief valve for Farmall M Hydraulics? posted by Lugaidh on July 04, 2001 at 08:54:29:
I missed your earlier messages. My neighbor and I both mow with M's on NH haybines. I had a 461, now have a 479, he had a 469 and now has a 488. The belly pumps work fine with a 3" or 3-1/2" cylinder. If the pump is worn they will be slow when hot. 30 wt hydraulic oil helps. I bale about 12,000 square bales all mowed with this haybine, so it is not occasional use. Note that the belly pump has four positions. When you pull the rod all the way back it will lift. There is a detent, and you can let go of the rod and it will stay back. When the cylinder stops and the pressure rises, the rod will self release to the raised position. When you push on the rod, it will let the cylinder down with the rod moving to the third position. As soon as the flow stops, the valve will block the flow in that position. To get full release of the cylinder you have to push the rod a bit further. On a flat field this is not important, but in hilly ground or going over terraces, the third position will keep the header from floating down further than where it first fell. This third position was for holding cultivators at the level they first hit the ground. The detent in the raise position is real handy as you can get both hands on the wheel as you try to cut a sharp corner where you have to lift the header as well. Getting down to the short rows. I think the belly pump is well suited to haybine operation. Make sure you have the rod end of the cylinder vented.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
