Re: ballast resistor for 12v conversion
Posted by Haas on July 05, 2001 at 06:09:45 from (129.37.117.108):
In Reply to: ballast resistor for 12v conversion posted by dan on July 04, 2001 at 09:25:23:
IF you measure the voltage with at voltmeter and the engine not running, it will show no voltage drop because there is no current flow. Not sure what will happen if you measure with the engine running. However, it the resistor is getting hot, it is working.
Post A Followup
: Re: Re: ballast resistor for 12v conversion
