Re: Follow-up on points and starter
Posted by Andy Martin on July 05, 2001 at 13:22:58 from (38.31.74.182):
In Reply to: Follow-up on points and starter posted by Rob in Wis. on July 05, 2001 at 12:02:42:
A "little chewed" sounds OK. If you have a bad chip or missing tooth on the ring gear I would be concerned, otherwise jsut run it.
Post A Followup
: Re: Re: Follow-up on points and starter
