Re: H has play in front end
Posted by The Undertaker on July 05, 2001 at 15:01:00 from (64.40.66.126):
In Reply to: H has play in front end posted by matt klein on July 05, 2001 at 09:46:50:
Matt:
All respondents so far have offered some valid points. The wobble, for certain, has to be result of wear to gears, bearings, bushings, and even the bolster shaft itself. Check out the underside of the top gear box cover to determine whether the main thrust bearing and spacers have worn sufficient to let the shaft move up cutting the under side of the cover. If such is the case, no doubt the boss on bottom of bolster casting has also cut into the top side of bolster shaft plate to which bottom bolster attaches.
"TU"
Post A Followup
: Re: Re: H has play in front end
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
