Re: Farmall B width
Posted by Dave BN on July 05, 2001 at 15:44:15 from (64.12.103.177):
In Reply to: Farmall B width posted by Steve K on July 05, 2001 at 08:36:03:
Steve, the rear wheels are adjustable in 4" increments (2" each side) from 64" to 92". I believe that is measured from the center of the wheel as they don't know how wide of tires your going to have. Adjustments are made by bolting the lugs of the wheels either on the inside of the hubs (Narrow) or the outside of the hubs(Wider). You then swap the wheels from one side of the tractor to the other (notice that the lugs are not centered on the wheel. The 3rd width adjustment is made by turning the hubs inside out(dished in or out). Combinations of these 3 adjustments give you 8 different widths. Sorry if this is more info than you wanted. Dave.
Post A Followup
: Re: Re: Farmall B width
