Re: New to Tractors! Got a 1941 MD and 1956 TD-61
Posted by Andy Martin on July 05, 2001 at 17:15:00 from (38.31.74.244):
In Reply to: New to Tractors! Got a 1941 MD and 1956 TD-61 posted by Brad Whitty on July 05, 2001 at 14:55:38:
Just pull the rim off the wheel, unless you are going to break the tire down yourself then you may want to do it on the tractor. It makes a nice fixture for holding the rim plus you can rotate it.
Auto parts stores can usually get rings and sleeve kits. Also check ads in magazines like Red Power.
I don't like wide fronts.
Post A Followup
: Re: Re: New to Tractors! Got a 1941 MD and 1956 TD-61
