Re: M missing
Posted by Farmer Bob on July 05, 2001 at 20:56:59 from (208.49.9.124):
In Reply to: M missing posted by Ed on July 05, 2001 at 19:12:52:
Ed, Does it do this with all plugs? or just one?
Have you changed out the plug(s) since putting in the new ones? Sometimes a new plug will be defective. Also consider changing the wires again. Are you using copper wire core wires? Also check for play in the distributor shaft. If there is quite a bit of play adjust the points down to .018 and see if it makes a difference.//FB
Post A Followup
: Re: Re: M missing
