Re: New Farmall A owner, Have question about hood bolts
Posted by Otis on July 05, 2001 at 21:41:19 from (65.163.40.211):
In Reply to: New Farmall A owner, Have question about hood bolts posted by Gregg on July 04, 2001 at 17:34:47:
The Dzus fastener is still widely used especially on aircraft. The stud fasteners counterpart are typically a receptacle or spring, either one riveted to the backing sheetmetal with 2 ea 3/32 countersunk rivets. The Farmalls used the spring type. Commonly, the stud or spring fails from over torqueing. The drawback with this stud fastener is that it tends to chaf into the sheetmetal itself, removing paint and gouging into the sheetmetal over time. Sounds to me like you have damaged/missing springs and or studs. Take a closer look behind the stud holes backing sheetmetal and see if there is a spring riveted across the hole. Otis
Post A Followup
: Re: Re: New Farmall A owner, Have question about hood bolts
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
