Re: Re: Cracked block repair good and not good
Posted by John on July 05, 2001 at 22:01:46 from (205.218.161.200):
In Reply to: Re: Cracked block repair good and not good posted by The Red on July 05, 2001 at 08:24:02:
Sounds to me like they remove the old cylinder
wall and then install a wet sleeve with o rings
sealing off the coolant.
Post A Followup
: Re: Re: Re: Cracked block repair good and not good
