Re: Re: Re: New to Tractors! Got a 1941 MD and 1956 TD-61
Posted by Haas on July 06, 2001 at 05:39:16 from (129.37.117.24):
In Reply to: Re: Re: New to Tractors! Got a 1941 MD and 1956 TD-61 posted by Brad Whitty on July 05, 2001 at 22:01:09:
Sounds like you got two good IH diesels. If the lift all hydraulic system does not work. First check that it has oil in it. Fill and level check is just in front of belt pulley on RH side. I would recommend draining and refilling it. Use non detergent 30 wt oil. If that does not do it, take the cover plate off the bottom just behind the lift all. You can then look up in there and see the shaft and coupling that drives the lift all pump. Some one may have removed the drive coupling. Could have happened at the tranny rebuild. I guess you are aware that the hydraulics are not live and only work when the clutch is engaged. Hydraulics are also one way only. Down is by gravity. The lift rod has three positions. Release is all the way forward, Hold is in the middle and lift is all the way back. You'll get 800 psi max out of the lift all. The PTO is engaged by the lever at the left side of the PTO. UP is engaged, down is off. It is not live and only turns when the clutch is engaged. It also may have gotten messed up when the tranny was rebuilt. When you find out what the rebuild stuff for that spare engine costs, you will wait awhile on that. Good Luck. Also, look here to see my Tractors. Also pictures of my Grandson.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
