Re: M missing
Posted by Ralph on July 06, 2001 at 06:04:40 from (209.254.130.15):
In Reply to: M missing posted by Ed on July 05, 2001 at 19:12:52:
Ed: You said leaving a 3/8 gap between wire and plug makes it run smoother. Having a gap increases the voltage build-up befor firing the plug. I've done this with a flooded engine when the plugs get wet with gas. It can help fire a wetplug. Are you getting oil buildup on the plugs? Wrong heat range of plug for the type of work its doing? Are all plugs needing this gap or just one? I'd supect fouled plug(s) first befor other things. ralph
Post A Followup
: Re: Re: M missing
