Cub clutch adjustment
Posted by Bayou Dave on July 06, 2001 at 13:40:20 from (209.124.227.80):
I have my friends yellow and white cub in my shop trying to adjust the clutch. I have the inspection plate off under the bell housing, the cotter key, and pin out of clutch shaft where it attaches to the throw-out bearing, and the clutch shaft loose. I can not turn the clevis at the end of the shaft. Is there a lock nut that is preventing it from turning? Not that I can get my hand in the hole, but I don't feel any threads on the shaft. Do I make the adjustment there, or do I adjust the 3 clutch dogs the throw-out bearing engages?
Post A Followup
: Re: Cub clutch adjustment
