Re: Hydraulic Pump Leak on M
Posted by Farmer Bob on July 06, 2001 at 22:21:29 from (208.49.9.201):
In Reply to: Hydraulic Pump Leak on M posted by Gary on July 06, 2001 at 19:48:33:
Gary, The only thing that could leak at the top of the bellhousing would either be the valve cover gasket or the breather tube which goes from the rear end of the head up to the pipe of the precleaner. This is if your are talking about at the very top of the bell. If the leak is somewhere else on top of the torque tube, check for some kind of backpressure blowing hydraulic oil out of the vent in the filler cap or could be a seal in the beltpulley housing but that would be tranny lube and not hyd. fluid. Need to look it over closely.//FB
Post A Followup
: Re: Re: Hydraulic Pump Leak on M
