Re: Re: Re: Re: Re: setting the timing
Posted by gene b on July 07, 2001 at 05:07:27 from (65.229.174.141):
In Reply to: Re: Re: Re: Re: setting the timing posted by farmall ed on July 06, 2001 at 18:56:43:
like the other guys say check that the rotor is on #1 when it is on TDC as you might have moved the gears when you put the points in easier to take all plugs out that makes for turning over the engine easierleave the cap off and you will get a feel for how it trips as each cycl goes on compression and make sure it is firing before putting the plugs back in
Post A Followup
: Re: Re: Re: Re: Re: Re: setting the timing
