Re: After reading on other hydraulic issue posts I have yet ANOTHER hydraulic question
Posted by Duner Wi on July 07, 2001 at 05:26:23 from (63.50.12.175):
In Reply to: After reading on other hydraulic issue posts I have yet ANOTHER hydraulic question posted by Lugaidh on July 06, 2001 at 18:43:14:
Om my M with a live pump from a 400 I went with a 3/4" or 1 in. inlet feed. Took out the belly pump and made a cover out of iron plate.
For the oil fill and breather I made a dip stick attached to a washer , then a pipe coupler with a piece of tail pipe extended up towards the gas tank. Put a oil breather cap on top of tail pipe.
You have to unscrew the coupler on upwards to add or check the oil but no more oil spilling out the top when the loader is in use. Is a hassle to mount the pump as 2 of the 4 holes don't line up. If you had the timing cover from a 400 might work. I made a clamping arrangement to hold the pump . I also have the verticle delco dist.
Valving is an IH addon on for double acting cylinders.
Post A Followup
: Re: Re: After reading on other hydraulic issue posts I have yet ANOTHER hydraulic question
