Re: help needed on charging troubles
Posted by Lloyd on July 07, 2001 at 05:56:07 from (66.43.215.83):
In Reply to: help needed on charging troubles posted by joe on July 06, 2001 at 16:39:50:
One way to tell if your charging system is working is to measure the voltage on your battery with everything off, then start it up and measure it again. If the system is charging, the voltage at the battery should be higher with the engine running.
Post A Followup
: Re: Re: help needed on charging troubles
