Re: leaking water pump on a (H)
Posted by Bob M on July 07, 2001 at 05:58:53 from (66.66.72.246):
In Reply to: leaking water pump on a (H) posted by Edd on July 06, 2001 at 15:31:35:
Your water pump leak might be fixed simply by tightening the packing nut. It's the large hex on the hub in FRONT of the fan blade, and which doesn't spin with the fan. If tightening the packing nut turn or two doesn't cure the leak you'll need to remove the pump, dig out the old seal packing and replace it with new. Also should look closely at the pump shaft where it runs thru the packing - if it's scored you'll need a new shaft too.
Post A Followup
: Re: Re: leaking water pump on a (H)
