Re: 49 cub with front end loose as a goose
Posted by George Willer on July 07, 2001 at 17:00:25 from (64.254.131.71):
In Reply to: 49 cub with front end loose as a goose posted by mike in ga. on July 07, 2001 at 15:50:16:
Mike,
You have an earlier version than your manual shows. Those parts will destroy each other if allowed to slop around. Notice that there is a left and a right arm. The difference is where the hole for the setscrew is. Consider this...drill and tap the other holes and add a second setscrew to each arm. It should become much more secure, even though not politically correct. I'll bet you will enjoy the ride more if you eliminate this play.
George Willer
Post A Followup
: Re: Re: 49 cub with front end loose as a goose
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
