460 steering ( jeff)
Posted by Ace Schrunk on July 07, 2001 at 17:07:41 from (152.163.201.52):
If steering is better one way than the other sounds like the U joint down at the front is not sliding on the splines it must slide or the whole steering shaft must move back and forth for the steering valve to work.
Post A Followup
: Re: 460 steering ( jeff)
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
