Re: 806 Diesel brakes squeal!
Posted by John -J on July 08, 2001 at 05:21:26 from (207.48.81.67):
In Reply to: 806 Diesel brakes squeal! posted by DAVE on July 07, 2001 at 21:38:15:
I guess an 806 is little compaired to somthing bigger. but on the brakes they are wet brakes, if they are squealing the disks must be worn off and metal to metal. there not that hard to remove and fix, a kit at the local IH place cost about $100 per side. It should just play with that 7ft hog. luck.
Post A Followup
: Re: Re: 806 Diesel brakes squeal!
