Re: What to use to replace valve housing stud nut washers?
Posted by The Red on July 08, 2001 at 14:48:28 from (12.75.197.59):
In Reply to: What to use to replace valve housing stud nut washers? posted by Lowell Davis on July 08, 2001 at 14:41:19:
I usually use a thin coat of gasket maker on the cork gasket on both sides and let it settup for 48 hours. A copper washer at the local hardware store will be fine. I have used steel flat washers also.
Post A Followup
: Re: Re: What to use to replace valve housing stud nut washers?
