Re: help!! M farmall has no fire.
Posted by Tom on July 08, 2001 at 20:30:55 from (64.12.105.179):
In Reply to: help!! M farmall has no fire. posted by Bill Smith on July 08, 2001 at 13:16:20:
Bill,
I spent several hours working to fix a similar problem with my SM a couple years ago. After trying many different changes and checks, I finally realized the insulated post which connects the points to the coil was grounded to the housing on the inside. Once I cleared the ground, everything was back to normal. I must have allowed the bolt to turn when the nut on the outside was tightened. Check to see if this has happened to you. Good luck.
Post A Followup
: Re: Re: help!! M farmall has no fire.
