Re: 560 with little to no spark
Posted by The Red on July 09, 2001 at 07:14:18 from (206.246.187.2):
In Reply to: 560 with little to no spark posted by Craig in Ohio on July 09, 2001 at 06:29:54:
I know some of the other 60 series have a resistor built into the wiring harness. Does your's by chance have that and then you also have a coil with a built in resistor, which would result in way too low of voltage pass the coil?
Post A Followup
: Re: Re: 560 with little to no spark
