Re: Fixed 2 problems over the weekend on the M
Posted by Haas on July 09, 2001 at 09:20:58 from (129.37.117.56):
In Reply to: Fixed 2 problems over the weekend on the M posted by Jon with an M on July 09, 2001 at 07:57:19:
I think the grease pipe you found is for the clutch release bearing, not the pilot bearing. If you have the Lift All out, you should be able to screw it back in pretty easy. The pilot bearing has a grease fitting, but it is located on the fly wheel. The parts book does not show a pipe associated with the pilot bearing. You have to turn the engine until the fitting appears at the hole in the very bottom of the clutch housing directly under the fly wheel. I think the flywheel is drilled to the center for lube of the pilot bearing with the grease fitting at the outer surface of the fly wheel. I believe the pipe you found should screw into the clutch release sleeve.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
