Re: Need advise on C throttle fix
Posted by Haas on July 09, 2001 at 14:26:29 from (129.37.117.19):
In Reply to: Need advise on C throttle fix posted by Paul Shuler on July 09, 2001 at 10:03:14:
The C throttle lever is a cast piece. However, it is good steel and you can have a welder fill the notch with weld metal and then shape the profile back with a grinder or a file. That's what I did with my C and it is fine now. Also had to use the 3 corner file on the notches.
Post A Followup
: Re: Re: Need advise on C throttle fix
