Re: Re: Re: Farmall C Cracked Head ??
Posted by Michael Soldan on July 09, 2001 at 16:59:18 from (216.46.140.186):
In Reply to: Re: Re: Farmall C Cracked Head ?? posted by Kenneth Fass on July 09, 2001 at 14:23:36:
Ken, I think David has hit the nail on the head and especially when you say it is heated about 1\4 the way down. I had a car rad that was causing a heating problem. I removed it , blocked the bottom outlet and filled it with CLR, a couple of jugs and let it sit for several hours in the sun, I dumped it ,rinsed it and put it back in the car and the flow was improved significantly...the rad shop route will in the long run be the best fix...Good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: Re: Re: Farmall C Cracked Head ??
