Re: 560 with little to no spark
Posted by TomH on July 09, 2001 at 18:58:26 from (206.101.85.65):
In Reply to: 560 with little to no spark posted by Craig in Ohio on July 09, 2001 at 06:29:54:
Could be a problem with the wires, bad insulation or bad connection could either be grounding it out or not supplying enough voltage to the coil. Shorts on the high voltage side are hard to find because it might only be arcing when the high voltage is present.
Post A Followup
: Re: Re: 560 with little to no spark
