Re: International 340 Utility
Posted by Farmall43 on July 11, 2001 at 09:59:39 from (216.93.117.20):
In Reply to: International 340 Utility posted by Chris Heiden on July 11, 2001 at 09:49:42:
Chris a number of things to look at. Does it have power steering? If not it will be a bear under a load. Does the loader mount on the rear axle? If not it is putting a lot of wheight on the bell houseing and that occassionally causes stress cracks. As for the T/A (Torque Amplifier) it may simply be out of adjustment but that almost never causes it to stop working. Usually that means at least $800 min. to reapair or replace. I don't have the IT manual right here with me but I am pretty sure you still have to split the tractor to do the T/A clutch and ramp and rollers. I have a 340 standard and it is a nice tractor. The brakes wear out to fast but it is a powerful little tractor. best of luck and read on. I am sure you will recieve many responses. Farmall43
Post A Followup
: Re: Re: International 340 Utility
