Re: 1959 International model140
Posted by Haas on July 11, 2001 at 18:15:42 from (129.37.117.6):
In Reply to: 1959 International model140 posted by Bob on July 11, 2001 at 16:06:24:
Front loaders were made for the 140s, but they are not common and are hard to find. I've seen one in my travels about 20 years ago. I've seen a few pictures. The PT0 on the 140 is not a live PTO. However, you will have no trouble with a belly mower. It will work find. The 6 ft belly mower is probably made my Woods. You can do light bush hog work, but it is really meant for finish mowing. If it is a 3 blade belly mower, there is not enough inertia in the blades to worry about pushing the tractor. By hydraulic, I assume he means the tractor hydraulic system lifts the mower up and down. The 140 is about 22 PTO HP. If the tractor is in good condition, $1900 is a good price. You should have no trouble getting your money back out of it.
Post A Followup
: Re: Re: 1959 International model140
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
