Re: Re: head gasket
Posted by Zonie on July 11, 2001 at 19:41:54 from (64.12.103.153):
In Reply to: Re: head gasket posted by Kendall on July 11, 2001 at 09:44:14:
from what I have seen the head gaskets for these old tractors are still builtjust as they were 50 yrs ago and are not coated.
Permatex makes a good copper sealer, I just got some a couple of weeks ago from Autozone.
As far as intake / exhaust gaskets go I use antisieze so I can get them back apart and reuse them if necessary.
also don't forget to retorque you head gasket after you get the engine good a hot. Most newer head gaskets don't need this but your dealing with 50 yr old designed gaskets and they do need it.
Post A Followup
: Re: Re: Re: head gasket
