Re: 300 Utility Clutch with TA Problem
Posted by Janicholson on March 15, 2009 at 09:51:37 from (64.83.225.108):
In Reply to: 300 Utility Clutch with TA Problem posted by Joe Kimbriel on March 15, 2009 at 08:52:53:
The book does not take into account the wear on pivots and pins in the system. The TA clutch is not being disengaged adequately and is hanging the pressure on the gears in the box. It will cause problems in the future if not adjusted. Look at the TA external clutch actuating lever where the shaft goes into the casting. (not the hand lever) Adjust this so it moves maybe 1/8th to 1/4" farther when the TA is in direct (forward) position, and the clutch pedal is down. Adjust it until the shifting is easy then a bit more. JimN
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
