Re: M gearshift boot?
Posted by Bob M on July 12, 2001 at 10:54:25 from (192.232.119.194):
In Reply to: M gearshift boot? posted by brianh on July 12, 2001 at 07:34:17:
Brian - Water accumulating the transmission does not necessarily have to come in thru the top. Around here (upstate NY), hot summer days and cool, humid nights cause a transmission to "breath" in moist air every evening as it cools down. Over the course of a summer a quart or more of condensation might show up in the tranny the size of an M - even one that's always kept under cover. Solutions: 1 - Keep the tranny properly filled with gear lube. (A full transmission contains less air space, hence less wet air gets sucked in each evening). 2 - Drain a couple quarts (or until water stops showing) out the bottom drain opening before the onset of freezing weather in the fall. Then top off with fresh gear lube.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
